Suzuki GSXR 1000 K4 battery replacement
  1. Suzuki GSXR 1000 K4 battery replacement, Battery: step 1, image 1 of 1
    • Suzuki GSXR 1000 K4
  2. Suzuki GSXR 1000 K4 battery replacement: step 2, image 1 of 1
    • First you have to remove the screws with an Imbus key (size 4) on the left and right side.
  3. Suzuki GSXR 1000 K4 battery replacement: step 3, image 1 of 3 Suzuki GSXR 1000 K4 battery replacement: step 3, image 2 of 3 Suzuki GSXR 1000 K4 battery replacement: step 3, image 3 of 3
    • You can now completely remove the seat.
  4. Suzuki GSXR 1000 K4 battery replacement: step 4, image 1 of 2 Suzuki GSXR 1000 K4 battery replacement: step 4, image 2 of 2
    • The screws can now be removed from the battery with a screwdriver PH 3 (alternatively a wrench or a socket wrench size 10 can be used).
    • Attention! There are nuts under the screws. These are not attached, so care must be taken when removing the screws that the nuts are not lost.
    • Before installation, both battery poles should be treated with polar grease or polish spray. Otherwise it can lead to corrosion, which can lead to contact problems.
  5. Suzuki GSXR 1000 K4 battery replacement: step 5, image 1 of 2 Suzuki GSXR 1000 K4 battery replacement: step 5, image 2 of 2
    • You can now seat the battery in its slot
  6. Suzuki GSXR 1000 K4 battery replacement: step 6, image 1 of 3 Suzuki GSXR 1000 K4 battery replacement: step 6, image 2 of 3 Suzuki GSXR 1000 K4 battery replacement: step 6, image 3 of 3
    • Before the battery can be reconnected all power consumers (light, ignition, etc.) must be shut off.
    • To prevent a short circuit and other damage to the motorcycle, make sure that the positive pole must first be connected !!!!!
    • After the positive pole is attached, it should be protected with the cover provided. If the cover is defective, it must be replaced. This protection is also a relevant criterion for TÜV.
    • After the plus pole is attached and protected, the negative pole can be attached.
To put the device back together follow the steps in reverse order.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Bianca Mueller
266 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 93
All Time: 8,086
