SuperSonic Matrix Mid SC-999 Headphone Jack Replacement
  1. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement, Back Cover: step 1, image 1 of 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: step 2, image 1 of 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: step 3, image 1 of 2 SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: step 3, image 2 of 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement, Headphone Jack: step 4, image 1 of 1
    • Locate the headphone jack on the device.
  5. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: step 5, image 1 of 2 SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: step 5, image 2 of 2
    • Desolder the 5 soldered connections (marked in red) that connect the headphone jack to the device.
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot, so be mindful in your handling.
Harris Dagha
866 Reputation
7 Guides authored
Dr Shaverz boyz Member of Dr Shaverz boyz
Community
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 234
