SuperSonic Matrix Mid SC-999 FM Antenna Replacement
  1. SuperSonic Matrix Mid SC-999 FM Antenna Replacement, Back Cover: step 1, image 1 of 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 FM Antenna Replacement: step 2, image 1 of 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 FM Antenna Replacement: step 3, image 1 of 2 SuperSonic Matrix Mid SC-999 FM Antenna Replacement: step 3, image 2 of 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 FM Antenna Replacement, Battery: step 4, image 1 of 3 SuperSonic Matrix Mid SC-999 FM Antenna Replacement, Battery: step 4, image 2 of 3 SuperSonic Matrix Mid SC-999 FM Antenna Replacement, Battery: step 4, image 3 of 3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 FM Antenna Replacement: step 5, image 1 of 3 SuperSonic Matrix Mid SC-999 FM Antenna Replacement: step 5, image 2 of 3 SuperSonic Matrix Mid SC-999 FM Antenna Replacement: step 5, image 3 of 3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
  6. SuperSonic Matrix Mid SC-999 FM Antenna Replacement, FM Antenna: step 6, image 1 of 2 SuperSonic Matrix Mid SC-999 FM Antenna Replacement, FM Antenna: step 6, image 2 of 2
    • Use a soldering iron to desolder the region circled in red.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so be aware of your surroundings.
  7. SuperSonic Matrix Mid SC-999 FM Antenna Replacement: step 7, image 1 of 2 SuperSonic Matrix Mid SC-999 FM Antenna Replacement: step 7, image 2 of 2
    • Desolder the FM antenna from the motherboard.
Harris Dagha
866 Reputation
7 Guides authored
Dr Shaverz boyz Member of Dr Shaverz boyz
Community
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 207
