Sungale Cyberus ID707WTA Speaker Replacement
  1. Sungale Cyberus ID707WTA Speaker Replacement, Battery: step 1, image 1 of 1
    • Press firmly on lower portion of the back cover and slide the cover towards the bottom to remove cover.
  2. Sungale Cyberus ID707WTA Speaker Replacement: step 2, image 1 of 1
    • Pull on the plug carefully until it releases from the port and simply pull the battery out after.
  3. Sungale Cyberus ID707WTA Speaker Replacement, Speaker: step 3, image 1 of 1
    • Pry open the casing with a plastic opening tool .
  4. Sungale Cyberus ID707WTA Speaker Replacement: step 4, image 1 of 2 Sungale Cyberus ID707WTA Speaker Replacement: step 4, image 2 of 2
    • Unscrew the five 4.5 mm screws to allow access to the motherboard.
    • Lift the motherboard and set it onto the backside of the screen.
  5. Sungale Cyberus ID707WTA Speaker Replacement: step 5, image 1 of 1
    • Pry the speaker out of retainer clip with iFixit pry tool.
  6. Sungale Cyberus ID707WTA Speaker Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Pry the speaker clip from the motherboard using tweezers.
Austin_Parkes
337 Reputation
3 Guides authored
IUPUI, Team S4-G4, Baechle Spring 2018 Member of IUPUI, Team S4-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 114
