Sun King Solo Solar Lantern Hand Strap Replacement
  1. Sun King Solo Solar Lantern Hand Strap Replacement, Locate and Remove the Screws: step 1, image 1 of 1
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Hand Strap Replacement, Separate the Device: step 2, image 1 of 1
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Hand Strap Replacement, Remove Strap: step 3, image 1 of 1
    • Remove both ends of the strap from the orange casing by pulling up.
  4. Sun King Solo Solar Lantern Hand Strap Replacement, Replace the Strap: step 4, image 1 of 1
    • Insert the ends of the new strap into the strap housing on both sides of the orange component.
    • Either strap housing (inner or outer) can be used to adjust the strap length.
Anna
595 Reputation
4 Guides authored
Michigan Tech, Team 1-3, Lauer Fall 2014 Member of Michigan Tech, Team 1-3, Lauer Fall 2014
MTU-LAUER-F14S1G3
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 321
