Sun King Solo Solar Lantern Casing Cleaning
  1. Sun King Solo Solar Lantern Casing Cleaning, Locate and Remove the Screws: step 1, image 1 of 1
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Casing Cleaning, Separate the Device: step 2, image 1 of 1
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Casing Cleaning, Cleaning the Casing: step 3, image 1 of 1
    Tool used on this step:
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Using a microfiber cleaning cloth, wipe the debris or condensation from the clear plastic of the device.
    • Buildup of condensation in the device could be due to broken or damaged seals. Click here for a seal replacement guide.
Anna
595 Reputation
4 Guides authored
Michigan Tech, Team 1-3, Lauer Fall 2014 Member of Michigan Tech, Team 1-3, Lauer Fall 2014
MTU-LAUER-F14S1G3
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 350
