SteelSeries Nimbus+ Thumbsticks Replacement
  1. SteelSeries Nimbus+ Thumbsticks Replacement, Remove the phone mount: step 1, image 1 of 2 SteelSeries Nimbus+ Thumbsticks Replacement, Remove the phone mount: step 1, image 2 of 2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. SteelSeries Nimbus+ Thumbsticks Replacement, Remove the sticker: step 2, image 1 of 1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. SteelSeries Nimbus+ Thumbsticks Replacement, Unscrew the back cover: step 3, image 1 of 1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. SteelSeries Nimbus+ Thumbsticks Replacement, Insert an opening pick: step 4, image 1 of 2 SteelSeries Nimbus+ Thumbsticks Replacement, Insert an opening pick: step 4, image 2 of 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. SteelSeries Nimbus+ Thumbsticks Replacement, Release the plastic clips: step 5, image 1 of 2 SteelSeries Nimbus+ Thumbsticks Replacement, Release the plastic clips: step 5, image 2 of 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. SteelSeries Nimbus+ Thumbsticks Replacement, Insert an opening pick: step 6, image 1 of 2 SteelSeries Nimbus+ Thumbsticks Replacement, Insert an opening pick: step 6, image 2 of 2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. SteelSeries Nimbus+ Thumbsticks Replacement, Release the plastic clips: step 7, image 1 of 2 SteelSeries Nimbus+ Thumbsticks Replacement, Release the plastic clips: step 7, image 2 of 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. SteelSeries Nimbus+ Thumbsticks Replacement, Unfold the back cover assembly: step 8, image 1 of 3 SteelSeries Nimbus+ Thumbsticks Replacement, Unfold the back cover assembly: step 8, image 2 of 3 SteelSeries Nimbus+ Thumbsticks Replacement, Unfold the back cover assembly: step 8, image 3 of 3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the battery cable: step 9, image 1 of 3 SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the battery cable: step 9, image 2 of 3 SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the battery cable: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. SteelSeries Nimbus+ Thumbsticks Replacement, Remove the back cover assembly: step 10, image 1 of 1
    • Remove the back cover assembly.
  11. SteelSeries Nimbus+ Thumbsticks Replacement, Unscrew the board: step 11, image 1 of 1
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
  12. SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the thumbstick board: step 12, image 1 of 3 SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the thumbstick board: step 12, image 2 of 3 SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the thumbstick board: step 12, image 3 of 3
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
  13. SteelSeries Nimbus+ Thumbsticks Replacement, Remove the board: step 13, image 1 of 1
    • Remove the board with the thumbsticks from the mainboard.
Repair didn’t go as planned? Check our Answers community for help.
Adriana Zwink
48,810 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
2 Comments
how can we find a replacement board with the thumbsticks?
Anne Taylor - Reply
I wonder the same thing
Bizkot -
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 27
All Time: 906
