Soundcore Liberty Air Charging Pins Replacement
  1. Soundcore Liberty Air Charging Pins Replacement, Charging Pins: step 1, image 1 of 2 Soundcore Liberty Air Charging Pins Replacement, Charging Pins: step 1, image 2 of 2
    • Clean the charging pins and case with a cotton swab.
  2. Soundcore Liberty Air Charging Pins Replacement: step 2, image 1 of 3 Soundcore Liberty Air Charging Pins Replacement: step 2, image 2 of 3 Soundcore Liberty Air Charging Pins Replacement: step 2, image 3 of 3
    • Remove the flat cover with a 1/16" punch tool by inserting it into the divot at the top of the earbud.
    • Be careful not to push too hard or upwards.
    • There is a lot of adhesive securing the cover, so using a mild heat will help loosen the adhesive.
  3. Soundcore Liberty Air Charging Pins Replacement: step 3, image 1 of 3 Soundcore Liberty Air Charging Pins Replacement: step 3, image 2 of 3 Soundcore Liberty Air Charging Pins Replacement: step 3, image 3 of 3
    Tool used on this step:
    $3.99
    Buy
    • Remove the black rubber cross from the bottom of the earbud with angled tweezers.
    • Do not poke through the rubber.
  4. Soundcore Liberty Air Charging Pins Replacement: step 4, image 1 of 3 Soundcore Liberty Air Charging Pins Replacement: step 4, image 2 of 3 Soundcore Liberty Air Charging Pins Replacement: step 4, image 3 of 3
    • Remove the top rubber rectangle with angled tweezers.
  5. Soundcore Liberty Air Charging Pins Replacement: step 5, image 1 of 3 Soundcore Liberty Air Charging Pins Replacement: step 5, image 2 of 3 Soundcore Liberty Air Charging Pins Replacement: step 5, image 3 of 3
    • Remove the white block from the earbud with blunt tweezers.
  6. Soundcore Liberty Air Charging Pins Replacement: step 6, image 1 of 3 Soundcore Liberty Air Charging Pins Replacement: step 6, image 2 of 3 Soundcore Liberty Air Charging Pins Replacement: step 6, image 3 of 3
    • Push out charging pins with the 1/16" tool.
    • Pull out the rest of the charging pin with angled tweezers
  7. Soundcore Liberty Air Charging Pins Replacement: step 7, image 1 of 2 Soundcore Liberty Air Charging Pins Replacement: step 7, image 2 of 2
    • Replace charging pins with angled tweezers.
To reassemble your device, follow these instructions in reverse order. Make sure to add all black rubber squares back in the same position that you removed them in order for them to fit properly. Avoid getting any moisture in or around the device during the repair in order to prevent any type of water damage.
Alyssa Punturo
145 Reputation
1 Guide authored
CSU Fullerton, Team 1-3, Bruce Fall 2022 Member of CSU Fullerton, Team 1-3, Bruce Fall 2022
CSUF-BRUCE-F22S1G3
2 Members
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 34
All Time: 895
