Sony Xplod CDX-MP30 LCD Replacement
  1. Sony Xplod CDX-MP30 LCD Replacement, Front Panel: step 1, image 1 of 3 Sony Xplod CDX-MP30 LCD Replacement, Front Panel: step 1, image 2 of 3 Sony Xplod CDX-MP30 LCD Replacement, Front Panel: step 1, image 3 of 3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 LCD Replacement, LCD: step 2, image 1 of 1
    • Unscrew the four (length - 11.11mm) phillips-head screws on the front screen.
  3. Sony Xplod CDX-MP30 LCD Replacement: step 3, image 1 of 3 Sony Xplod CDX-MP30 LCD Replacement: step 3, image 2 of 3 Sony Xplod CDX-MP30 LCD Replacement: step 3, image 3 of 3
    • Use two fingers to create a small gap on the top of the faceplate, as indicated in the picture.
  4. Sony Xplod CDX-MP30 LCD Replacement: step 4, image 1 of 3 Sony Xplod CDX-MP30 LCD Replacement: step 4, image 2 of 3 Sony Xplod CDX-MP30 LCD Replacement: step 4, image 3 of 3
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
    • Insert the flat end of the Heavy-duty Spudger into the opening you created.
    • Slide it to the right carefully, until you feel the screen pop off.
    • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
  5. Sony Xplod CDX-MP30 LCD Replacement: step 5, image 1 of 2 Sony Xplod CDX-MP30 LCD Replacement: step 5, image 2 of 2
    • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
  6. Sony Xplod CDX-MP30 LCD Replacement: step 6, image 1 of 1
Kyle
114 Reputation
2 Guides authored
Cal Poly, Team 5-35, Amido Fall 2011 Member of Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 14
All Time: 2,332
