Sony XPERIA Tablet Z Screen Replacement
  1. Sony XPERIA Tablet Z Screen Replacement, Screen: step 1, image 1 of 3 Sony XPERIA Tablet Z Screen Replacement, Screen: step 1, image 2 of 3 Sony XPERIA Tablet Z Screen Replacement, Screen: step 1, image 3 of 3
    • Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
  2. Sony XPERIA Tablet Z Screen Replacement: step 2, image 1 of 3 Sony XPERIA Tablet Z Screen Replacement: step 2, image 2 of 3 Sony XPERIA Tablet Z Screen Replacement: step 2, image 3 of 3
    • Gently separate the gold ribbon cable from the back side by lifting up with plastic opening tool and separating from the adhesive.
    • Separate the black ribbon cable from the back of screen by lifting up with a plastic opening tool.
  3. Sony XPERIA Tablet Z Screen Replacement: step 3, image 1 of 1
    • Use a hairdryer, heat gun, or something suitable to heat the edge of the screen to soften the adhesive holding the screen.
    • Only heat enough to loosen the adhesive but not damage the tablet.
  4. Sony XPERIA Tablet Z Screen Replacement: step 4, image 1 of 1
    • Gently pry the edge of the screen working around while heating.
  5. Sony XPERIA Tablet Z Screen Replacement: step 5, image 1 of 1
    • Clean adhesive from perimeter of frame to prepare for new screen.
8 other people completed this guide.
Gustavo Correa
373 Reputation
1 Guide authored
IUPUI, Team S5-G1, Harley Summer 2017 Member of IUPUI, Team S5-G1, Harley Summer 2017
IUPUI-HARLEY-SU17S5G1
4 Members
3 Guides authored
5 Comments
اريدشراءاريدشراءشاشه جديده
kore ares - Reply
Do you need adhesive to attach new screen, & if so, what do you use?
Martha Morrison - Reply
i would also like to know what adhesive you use to reatach the screen. thanks
Blaze - Reply
Wooo its self explanatory.Good work
Duncan Mwaniki - Reply
Where do I get the Screen if I'm in South Africa
Thembekile Nizel - Reply
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 56
All Time: 6,917
