Sony Vaio VPCW211AX Keyboard Replacement
  1. Sony Vaio VPCW211AX Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Start with the laptop face up on a flat surface.
  2. Sony Vaio VPCW211AX Keyboard Replacement: step 2, image 1 of 1
    • Open the laptop with the keyboard facing you.
  3. Sony Vaio VPCW211AX Keyboard Replacement: step 3, image 1 of 2 Sony Vaio VPCW211AX Keyboard Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
    • Be careful around the edges; work your way around the keyboard until all of it is detached.
    • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
  4. Sony Vaio VPCW211AX Keyboard Replacement: step 4, image 1 of 2 Sony Vaio VPCW211AX Keyboard Replacement: step 4, image 2 of 2
    • Carefully detach the ribbon from the base of the computer with your hands.
    • Remove the keyboard.
Giselle Dougan
760 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 532
