Sony Vaio VPCW211AX Battery Replacement
  1. Sony Vaio VPCW211AX Battery  Replacement, Flat Laptop: step 1, image 1 of 1
    • Start with the laptop closed on a flat surface.
  2. Sony Vaio VPCW211AX Battery  Replacement, Flip: step 2, image 1 of 1
    • Flip the laptop so the bottom side is facing up.
  3. Sony Vaio VPCW211AX Battery  Replacement, Lock/Unlock: step 3, image 1 of 1
    • Place your hands on the lock/unlock function on the laptop on either side on the bottom of the laptop and slide.
  4. Sony Vaio VPCW211AX Battery  Replacement, Lift: step 4, image 1 of 1
    • Lift and pull the battery up away from you
  5. Sony Vaio VPCW211AX Battery  Replacement, Remove: step 5, image 1 of 1
    • Carefully remove the battery from it's slot
Giselle Dougan
760 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 657
