Sony Vaio VPCEG26FX RAM Replacement
  1. Sony Vaio VPCEG26FX  RAM Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop so the bottom is facing up with the model number visible.
  2. Sony Vaio VPCEG26FX  RAM Replacement: step 2, image 1 of 2 Sony Vaio VPCEG26FX  RAM Replacement: step 2, image 2 of 2
    • Slide the lock switch down until you hear a click to unlock the battery.
  3. Sony Vaio VPCEG26FX  RAM Replacement: step 3, image 1 of 2 Sony Vaio VPCEG26FX  RAM Replacement: step 3, image 2 of 2
    • Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
  4. Sony Vaio VPCEG26FX  RAM Replacement: step 4, image 1 of 2 Sony Vaio VPCEG26FX  RAM Replacement: step 4, image 2 of 2
    • Remove the battery from the battery compartment.
  5. Sony Vaio VPCEG26FX  RAM Replacement, RAM: step 5, image 1 of 1
    • After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
  6. Sony Vaio VPCEG26FX  RAM Replacement: step 6, image 1 of 1
    • Remove the single screw holding the panel in place using the JIS #0 screwdriver.
  7. Sony Vaio VPCEG26FX  RAM Replacement: step 7, image 1 of 3 Sony Vaio VPCEG26FX  RAM Replacement: step 7, image 2 of 3 Sony Vaio VPCEG26FX  RAM Replacement: step 7, image 3 of 3
    • Remove the green circuit board by dislodging the circuit it is attached to.
    • Unhook it and remove it from the device.
Sara Alfaro
531 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 732
