Sony Vaio VPC-Y2190X RAM Card Replacement
  1. Sony Vaio VPC-Y2190X RAM Card Replacement, Battery: step 1, image 1 of 1
    • Flip your laptop so that the bottom is facing up.
  2. Sony Vaio VPC-Y2190X RAM Card Replacement: step 2, image 1 of 1
    • Slide the “Lock” switch to the right.
    • Slide and hold the “Release” switch to the left.
  3. Sony Vaio VPC-Y2190X RAM Card Replacement: step 3, image 1 of 2 Sony Vaio VPC-Y2190X RAM Card Replacement: step 3, image 2 of 2
    • While holding the “Release” switch, lift the lip of the battery.
    • Lift the battery up and out of the laptop.
  4. Sony Vaio VPC-Y2190X RAM Card Replacement, RAM Card: step 4, image 1 of 2 Sony Vaio VPC-Y2190X RAM Card Replacement, RAM Card: step 4, image 2 of 2
    • Use a #0PH screwdriver to unscrew the three 4.80mm screws.
    • Remove the panel.
  5. Sony Vaio VPC-Y2190X RAM Card Replacement: step 5, image 1 of 1
    • Pull the metal tabs in opposite directions, away from the RAM card.
    • The RAM card will swing upwards.
  6. Sony Vaio VPC-Y2190X RAM Card Replacement: step 6, image 1 of 1
    • Grab the RAM card from its center.
    • Gently pull the RAM card out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 325
