Sony Vaio VPC-Y2190X Hard Drive Replacement
  1. Sony Vaio VPC-Y2190X Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Flip your laptop so that the bottom is facing up.
  2. Sony Vaio VPC-Y2190X Hard Drive Replacement: step 2, image 1 of 1
    • Slide the “Lock” switch to the right.
    • Slide and hold the “Release” switch to the left.
  3. Sony Vaio VPC-Y2190X Hard Drive Replacement: step 3, image 1 of 2 Sony Vaio VPC-Y2190X Hard Drive Replacement: step 3, image 2 of 2
    • While holding the “Release” switch, lift the lip of the battery.
    • Lift the battery up and out of the laptop.
  4. Sony Vaio VPC-Y2190X Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Using a #0PH screwdriver, unscrew the three 4.80mm screws on the back of the device.
    • The screws are held into the panel by washers, they will not fall out once unscrewed.
  5. Sony Vaio VPC-Y2190X Hard Drive Replacement: step 5, image 1 of 1
    • Remove the panel.
    • Use the #0PH screwdriver to remove the four 3.61mm screws.
  6. Sony Vaio VPC-Y2190X Hard Drive Replacement: step 6, image 1 of 2 Sony Vaio VPC-Y2190X Hard Drive Replacement: step 6, image 2 of 2
    • Carefully lift the hard drive.
    • Remove the hard drive by pulling it to the left.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 349
