Sony Vaio VGN-SR140E RAM Replacement
  1. Sony Vaio VGN-SR140E RAM Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E RAM Replacement: step 2, image 1 of 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E RAM Replacement: step 3, image 1 of 2 Sony Vaio VGN-SR140E RAM Replacement: step 3, image 2 of 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E RAM Replacement, RAM: step 4, image 1 of 1
    • Using a Phillips #1 screwdriver, remove both screws. The screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E RAM Replacement: step 5, image 1 of 2 Sony Vaio VGN-SR140E RAM Replacement: step 5, image 2 of 2
    • Lift the thin black plastic cover to access the RAM.
  6. Sony Vaio VGN-SR140E RAM Replacement: step 6, image 1 of 2 Sony Vaio VGN-SR140E RAM Replacement: step 6, image 2 of 2
    • Apply light outward pressure to the locks on either side of the RAM. Rotate the RAM up slightly. Pull the RAM toward you to remove it.
  7. Sony Vaio VGN-SR140E RAM Replacement: step 7, image 1 of 3 Sony Vaio VGN-SR140E RAM Replacement: step 7, image 2 of 3 Sony Vaio VGN-SR140E RAM Replacement: step 7, image 3 of 3
    • Using the same light outward pressure on the locks, lift the secondary RAM up and slide it away from you to remove it from its slot.
Jeremy
722 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 481
