Sony Vaio SVE111B11L Screen Replacement
  1. Sony Vaio SVE111B11L  Screen Replacement, Battery: step 1, image 1 of 2 Sony Vaio SVE111B11L  Screen Replacement, Battery: step 1, image 2 of 2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L  Screen Replacement: step 2, image 1 of 1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L  Screen Replacement: step 3, image 1 of 1
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L  Screen Replacement, Keyboard Assembly: step 4, image 1 of 1
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L  Screen Replacement: step 5, image 1 of 1
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L  Screen Replacement: step 6, image 1 of 1
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L  Screen Replacement: step 7, image 1 of 3 Sony Vaio SVE111B11L  Screen Replacement: step 7, image 2 of 3 Sony Vaio SVE111B11L  Screen Replacement: step 7, image 3 of 3
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
  8. Sony Vaio SVE111B11L  Screen Replacement, Motherboard: step 8, image 1 of 1
    • Remove charging adaptor. Some charge may still be in the battery or computer.
    • DO NOT touch connectors or copper yellow connector.
    • Take the covers on the bottom of the laptop off.
  9. Sony Vaio SVE111B11L  Screen Replacement: step 9, image 1 of 1
    • Locate and remove the screws holding the motherboard down.
    • Screws: L 4.6mm X D 1.85mm
  10. Sony Vaio SVE111B11L  Screen Replacement: step 10, image 1 of 3 Sony Vaio SVE111B11L  Screen Replacement: step 10, image 2 of 3 Sony Vaio SVE111B11L  Screen Replacement: step 10, image 3 of 3
    • Locate the wires and connectors and remove them from the motherboard.
  11. Sony Vaio SVE111B11L  Screen Replacement: step 11, image 1 of 2 Sony Vaio SVE111B11L  Screen Replacement: step 11, image 2 of 2
    • Lift the mother board out and safely put it to the side.
  12. Sony Vaio SVE111B11L  Screen Replacement, Screen: step 12, image 1 of 2 Sony Vaio SVE111B11L  Screen Replacement, Screen: step 12, image 2 of 2
    • Remove charging adaptor and battery. Some charge may still be in the battery or computer.
    • Locate screws. L 3.35mm X D 1.8mm
    • Remove Screws.
    • Lay the screen on a hard flat surface.
    • Remove hinges and wires for ease of removal.
  13. Sony Vaio SVE111B11L  Screen Replacement: step 13, image 1 of 1
    • Gently remove the screen cover.
    • Be careful of the camera at the top of the screen.
    • Be careful of the seal tape between the cover and the screen.
  14. Sony Vaio SVE111B11L  Screen Replacement: step 14, image 1 of 3 Sony Vaio SVE111B11L  Screen Replacement: step 14, image 2 of 3 Sony Vaio SVE111B11L  Screen Replacement: step 14, image 3 of 3
    • Locate the wires and connectors.
    • Unplug the wires from the connectors.
    • Be careful of the yellow tape around the connection.
  15. Sony Vaio SVE111B11L  Screen Replacement: step 15, image 1 of 2 Sony Vaio SVE111B11L  Screen Replacement: step 15, image 2 of 2
    • Gently lift the screen assembly up and out.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 1,242
