Sony Vaio PCG-F420 Hard Drive Replacement
  1. Sony Vaio PCG-F420 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
  2. Sony Vaio PCG-F420 Hard Drive Replacement: step 2, image 1 of 1
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
  3. Sony Vaio PCG-F420 Hard Drive Replacement, Keyboard: step 3, image 1 of 1
    • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
  4. Sony Vaio PCG-F420 Hard Drive Replacement: step 4, image 1 of 1
    • Unlock the cover between the keyboard and screen.
    • Gently slide it to the right and lift it up.
    • Exercise caution to avoid excessive force, as wires are connected.
    • Be mindful not to pull the keyboard too forcefully as it remains connected to wires, which we will address in the next step.
  5. Sony Vaio PCG-F420 Hard Drive Replacement: step 5, image 1 of 1
    • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
    • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
  6. Sony Vaio PCG-F420 Hard Drive Replacement: step 6, image 1 of 1
    • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
  7. Sony Vaio PCG-F420 Hard Drive Replacement: step 7, image 1 of 1
    • Carefully unplug the ribbon cable using a pair of tweezers.
    • Lift up the white bar near the connection to the motherboard, and lightly lift the ribbon to release it from the motherboard.
  8. Sony Vaio PCG-F420 Hard Drive Replacement: step 8, image 1 of 2 Sony Vaio PCG-F420 Hard Drive Replacement: step 8, image 2 of 2
    • Now, pull on the ribbon cable, and it will detach from the motherboard.
    • Your keyboard is now safely detached, allowing for necessary repairs or replacements.
  9. Sony Vaio PCG-F420 Hard Drive Replacement: step 9, image 1 of 1
    • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
  10. Sony Vaio PCG-F420 Hard Drive Replacement, Hard Drive: step 10, image 1 of 1
    • The hard drive is the metal box in the middle. Use your Philips Head screwdriver to remove the four screws that attach the cage to the motherboard.
  11. Sony Vaio PCG-F420 Hard Drive Replacement: step 11, image 1 of 1
    • The Hard Drive box is now unfastened. You can free it from the laptop by pulling up, but be careful because it is held in place by the surrounding metal pieces so a little strength, yet care, is needed. When free, do not immediately remove it, there is a ribbon cable connecting it to the laptop.
  12. Sony Vaio PCG-F420 Hard Drive Replacement: step 12, image 1 of 1
    • Slowly pull the hard drive away from the ribbon by holding the plastic connector at the end of the ribbon and pulling on the Hard Drive. The Hard Drive should now be completely free of the laptop and the two connecting ends displayed in the picture should be visible.
  13. Sony Vaio PCG-F420 Hard Drive Replacement: step 13, image 1 of 1
    • The hard drive is attached to the metal outer case by four screws, two on each side.
  14. Sony Vaio PCG-F420 Hard Drive Replacement: step 14, image 1 of 1
    • The Hard Drive is now exposed. You are now free to replace it, clean it, or repair it.
john franzino
1 Reputation
1 Guide authored
Cal Poly, Team 29-77, Johann Spring 2010 Member of Cal Poly, Team 29-77, Johann Spring 2010
CPSU-JOHANN-S10S29G77
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 29
All Time: 7,964
