Sony Vaio PCG-981L Battery Replacement
  1. Sony Vaio PCG-981L Battery Replacement, Battery: step 1, image 1 of 1
    • Before starting, be sure the device is turned off and disconnected from any power cords.
    • Place the device on a flat surface.
  2. Sony Vaio PCG-981L Battery Replacement: step 2, image 1 of 1
    • Rotate the device 90° counterclockwise until the battery cover is in front of you.
    • The battery cover is located in the lower right side of the device in this new orientation.
  3. Sony Vaio PCG-981L Battery Replacement: step 3, image 1 of 1
    • Flip the laptop over so that the bottom is facing up but the battery cover is still facing you.
    • In this new orientation, the battery cover is located on the left side.
  4. Sony Vaio PCG-981L Battery Replacement: step 4, image 1 of 1
    • To remove the battery cover, use your hands to slide it upwards.
  5. Sony Vaio PCG-981L Battery Replacement: step 5, image 1 of 3 Sony Vaio PCG-981L Battery Replacement: step 5, image 2 of 3 Sony Vaio PCG-981L Battery Replacement: step 5, image 3 of 3
    • Once lifted, the battery cover should flip open.
    • Now, carefully remove the battery from the device.
  6. Sony Vaio PCG-981L Battery Replacement: step 6, image 1 of 2 Sony Vaio PCG-981L Battery Replacement: step 6, image 2 of 2
    • Now, the battery should be completely removed from the device.
    • Be sure to dispose of the old battery properly and then you are finished.
Enjoy your new battery.
Gabriel Camorlinga
43 Reputation
2 Guides authored
Cal Poly, Team 18-68, Johann Spring 2010 Member of Cal Poly, Team 18-68, Johann Spring 2010
CPSU-JOHANN-S10S18G68
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 3,802
