Introduction
This guide will help you disassemble your Sony Vaio VGN-FS640 laptop in order to replace or remove the optical drive.
With the bottom of the laptop facing up, locate the RAM cover.
The RAM is covered by the panel with four columns of vents.
Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
Slide the cover until it is free from the laptop case.
Lift the cover to remove.
Locate the screws highlighted here. There are 16 total.
Using a Phillips #0 screwdriver, remove the screws (Length: 6.8mm) and place them on a tray for later use.
Locate and remove the screws (Length: 5.8mm) affixing the drive to the laptop frame.
Gently slide the drive away from the body of the laptop until it is disconnected.
Lift the drive out.
3 other people completed this guide.
2 Comments
sve 151a11w sony disk error plz help me sir
