Sony Vaio VGN-FS640 Hard Drive Replacement
  1. Sony Vaio VGN-FS640 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 Hard Drive Replacement: step 2, image 1 of 1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 Hard Drive Replacement: step 3, image 1 of 2 Sony Vaio VGN-FS640 Hard Drive Replacement: step 3, image 2 of 2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: step 4, image 1 of 3 Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: step 4, image 2 of 3 Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: step 4, image 3 of 3
    • Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
    • Slide the cover until it is free from the laptop case.
    • Lift the cover to remove.
  5. Sony Vaio VGN-FS640 Hard Drive Replacement: step 5, image 1 of 3 Sony Vaio VGN-FS640 Hard Drive Replacement: step 5, image 2 of 3 Sony Vaio VGN-FS640 Hard Drive Replacement: step 5, image 3 of 3
    • Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
    • Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
    • The Hard Drive should now be disconnected.
    • Lift the drive out with the tab on the tray.
2 other people completed this guide.
Matt McCarty
220 Reputation
2 Guides authored
Cal Poly, Team 24-32, Regan Spring 2010 Member of Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 Members
16 Guides authored
One Comment
cant sign to recover my external hard drive
manivanan88 - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 10,582
