Sony Vaio PCG-61411L Keyboard Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Sony Vaio PCG-61411L Keyboard Replacement, Battery: step 1, image 1 of 3 Sony Vaio PCG-61411L Keyboard Replacement, Battery: step 1, image 2 of 3 Sony Vaio PCG-61411L Keyboard Replacement, Battery: step 1, image 3 of 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L Keyboard Replacement: step 2, image 1 of 3 Sony Vaio PCG-61411L Keyboard Replacement: step 2, image 2 of 3 Sony Vaio PCG-61411L Keyboard Replacement: step 2, image 3 of 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L Keyboard Replacement, Hard Drive: step 3, image 1 of 1
    • The hard drive panel is located in the bottom right corner of the device.
  4. Sony Vaio PCG-61411L Keyboard Replacement: step 4, image 1 of 2 Sony Vaio PCG-61411L Keyboard Replacement: step 4, image 2 of 2
    • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
    • Remove the panel by pulling it up towards yourself.
  5. Sony Vaio PCG-61411L Keyboard Replacement: step 5, image 1 of 3 Sony Vaio PCG-61411L Keyboard Replacement: step 5, image 2 of 3 Sony Vaio PCG-61411L Keyboard Replacement: step 5, image 3 of 3
    • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
    • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
    • Carefully remove the silver hard drive cover.
  6. Sony Vaio PCG-61411L Keyboard Replacement: step 6, image 1 of 3 Sony Vaio PCG-61411L Keyboard Replacement: step 6, image 2 of 3 Sony Vaio PCG-61411L Keyboard Replacement: step 6, image 3 of 3
    • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
  7. Sony Vaio PCG-61411L Keyboard Replacement, Optical Disc Drive: step 7, image 1 of 2 Sony Vaio PCG-61411L Keyboard Replacement, Optical Disc Drive: step 7, image 2 of 2
    • Remove the 5mm screws with the PH0 screwdriver.
    • Remove the 3mm screws with the PH0 screwdriver.
  8. Sony Vaio PCG-61411L Keyboard Replacement: step 8, image 1 of 2 Sony Vaio PCG-61411L Keyboard Replacement: step 8, image 2 of 2
    • Lift the backplate from bottom right and left corner and remove it from the laptop.
  9. Sony Vaio PCG-61411L Keyboard Replacement: step 9, image 1 of 2 Sony Vaio PCG-61411L Keyboard Replacement: step 9, image 2 of 2
    • Slide your finger from the right of the optical disc and pull the optical disc from right to left.
  10. Sony Vaio PCG-61411L Keyboard Replacement, Keyboard: step 10, image 1 of 2 Sony Vaio PCG-61411L Keyboard Replacement, Keyboard: step 10, image 2 of 2
    • Push keyboard out from the hole located in the optical drives original location.
  11. Sony Vaio PCG-61411L Keyboard Replacement: step 11, image 1 of 3 Sony Vaio PCG-61411L Keyboard Replacement: step 11, image 2 of 3 Sony Vaio PCG-61411L Keyboard Replacement: step 11, image 3 of 3
    • Remove the keyboard cover by gently pulling along the sides until it is removed completely.
  12. Sony Vaio PCG-61411L Keyboard Replacement: step 12, image 1 of 2 Sony Vaio PCG-61411L Keyboard Replacement: step 12, image 2 of 2
    • Disconnect the keyboard by pulling the connection wire in the opposite direction of where it's connected.
Patrick Jean Baptiste
214 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,387
