Sony Vaio PCG-4G1L Keyboard Replacement
  1. Sony Vaio PCG-4G1L Keyboard Replacement, Battery: step 1, image 1 of 1
    • Turn off the computer and disconnect the charging cable.
    • Failing to unplug the cable can result in electric shock.
  2. Sony Vaio PCG-4G1L Keyboard Replacement: step 2, image 1 of 2 Sony Vaio PCG-4G1L Keyboard Replacement: step 2, image 2 of 2
    • Slide battery release toggle switch towards the "RELEASE" print.
  3. Sony Vaio PCG-4G1L Keyboard Replacement: step 3, image 1 of 3 Sony Vaio PCG-4G1L Keyboard Replacement: step 3, image 2 of 3 Sony Vaio PCG-4G1L Keyboard Replacement: step 3, image 3 of 3
    • Apply pressure with your thumb on the grip.
    • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
  4. Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: step 4, image 1 of 2 Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: step 4, image 2 of 2
    • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
  5. Sony Vaio PCG-4G1L Keyboard Replacement: step 5, image 1 of 2 Sony Vaio PCG-4G1L Keyboard Replacement: step 5, image 2 of 2
    • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
    • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
  6. Sony Vaio PCG-4G1L Keyboard Replacement: step 6, image 1 of 3 Sony Vaio PCG-4G1L Keyboard Replacement: step 6, image 2 of 3 Sony Vaio PCG-4G1L Keyboard Replacement: step 6, image 3 of 3
    • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
    • Use the plastic opening tool to release the clamp.
    • Using slight pressure, remove the ribbon cable with your fingers.
2 other people completed this guide.
Cole Collins
175 Reputation
4 Guides authored
USF Tampa, Team 2-3, Cagle Fall 2016 Member of USF Tampa, Team 2-3, Cagle Fall 2016
USFT-CAGLE-F16S2G3
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 728
