Sony Vaio PCG-4121GL AUX Board Replacement
  1. Sony Vaio PCG-4121GL AUX Board Replacement, Battery: step 1, image 1 of 2 Sony Vaio PCG-4121GL AUX Board Replacement, Battery: step 1, image 2 of 2
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL AUX Board Replacement: step 2, image 1 of 3 Sony Vaio PCG-4121GL AUX Board Replacement: step 2, image 2 of 3 Sony Vaio PCG-4121GL AUX Board Replacement: step 2, image 3 of 3
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL AUX Board Replacement: step 3, image 1 of 1
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL AUX Board Replacement: step 4, image 1 of 3 Sony Vaio PCG-4121GL AUX Board Replacement: step 4, image 2 of 3 Sony Vaio PCG-4121GL AUX Board Replacement: step 4, image 3 of 3
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
  5. Sony Vaio PCG-4121GL AUX Board Replacement, AUX Board: step 5, image 1 of 2 Sony Vaio PCG-4121GL AUX Board Replacement, AUX Board: step 5, image 2 of 2
    • Remove seven 3mm Phillips #0 screws from the bottom of the computer.
    • Remove eight 5mm Phillips #0 screws.
  6. Sony Vaio PCG-4121GL AUX Board Replacement: step 6, image 1 of 3 Sony Vaio PCG-4121GL AUX Board Replacement: step 6, image 2 of 3 Sony Vaio PCG-4121GL AUX Board Replacement: step 6, image 3 of 3
    • Carefully remove the disk drive from its compartment.
  7. Sony Vaio PCG-4121GL AUX Board Replacement: step 7, image 1 of 2 Sony Vaio PCG-4121GL AUX Board Replacement: step 7, image 2 of 2
    • Remove the three 2mm Phillips #00 screws located on the top right edge.
  8. Sony Vaio PCG-4121GL AUX Board Replacement: step 8, image 1 of 2 Sony Vaio PCG-4121GL AUX Board Replacement: step 8, image 2 of 2
    • Gently pull apart the top and bottom plastic bodies.
    • Carefully remove the cable connectors.
    • Slowly detach bottom component to avoid tearing wires/connectors.
  9. Sony Vaio PCG-4121GL AUX Board Replacement: step 9, image 1 of 3 Sony Vaio PCG-4121GL AUX Board Replacement: step 9, image 2 of 3 Sony Vaio PCG-4121GL AUX Board Replacement: step 9, image 3 of 3
    • Pull apart your device and set aside the screen of your laptop.
    • Locate the AUX Board in the top right of the computer body.
  10. Sony Vaio PCG-4121GL AUX Board Replacement: step 10, image 1 of 2 Sony Vaio PCG-4121GL AUX Board Replacement: step 10, image 2 of 2
    • Remove the 2mm Phillips #0 screw.
    • Carefully pull the cable connector out to the left.
    • Once both are no longer connected remove the AUX Board completely.
2 other people completed this guide.
Miguel Camarena
367 Reputation
3 Guides authored
Cal Poly, Team S2-G2, White Winter 2019 Member of Cal Poly, Team S2-G2, White Winter 2019
CPSU-WHITE-W19S2G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 1,489
