Sony Vaio PCG-41216L Network Card Replacement
  1. Sony Vaio PCG-41216L Network Card Replacement, Network Card: step 1, image 1 of 2 Sony Vaio PCG-41216L Network Card Replacement, Network Card: step 1, image 2 of 2
    • Flip the laptop over to begin the process.
    • Make sure the laptop is turned off and unplugged from the power cable.
  2. Sony Vaio PCG-41216L Network Card Replacement: step 2, image 1 of 3 Sony Vaio PCG-41216L Network Card Replacement: step 2, image 2 of 3 Sony Vaio PCG-41216L Network Card Replacement: step 2, image 3 of 3
    • Remove the two 7mm Phillips #1 screws holding the battery cover.
  3. Sony Vaio PCG-41216L Network Card Replacement: step 3, image 1 of 3 Sony Vaio PCG-41216L Network Card Replacement: step 3, image 2 of 3 Sony Vaio PCG-41216L Network Card Replacement: step 3, image 3 of 3
    • Locate the networking card above the hard drive and next to the RAM.
    • Carefully pop out the two connection cables from the networking card.
  4. Sony Vaio PCG-41216L Network Card Replacement: step 4, image 1 of 3 Sony Vaio PCG-41216L Network Card Replacement: step 4, image 2 of 3 Sony Vaio PCG-41216L Network Card Replacement: step 4, image 3 of 3
    • Remove the black tape to uncover the screw underneath.
    • Remove the 3mm Phillips head screw.
    • When loosening the screw, the network card will automatically lift itself to a diagonal position. This is normal.
  5. Sony Vaio PCG-41216L Network Card Replacement: step 5, image 1 of 2 Sony Vaio PCG-41216L Network Card Replacement: step 5, image 2 of 2
    • Pull the network card straight out in the direction it is resting in.
    • Reinsert the new network card diagonally and into the same position as the previous one.
    • To screw the new network card back into place, you will need to push the network card back down onto the motherboard.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 585
