Sony Vaio PCG-3C2L Hard Drive Replacement
  1. Sony Vaio PCG-3C2L Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Turn your computer over so the bottom is facing up.
    • The battery should be in the top on the back of the computer.
  2. Sony Vaio PCG-3C2L Hard Drive Replacement: step 2, image 1 of 2 Sony Vaio PCG-3C2L Hard Drive Replacement: step 2, image 2 of 2
    • Initially, the "lock" button should be pushed all the way to the left. To unlock the battery, move the lock button from the left to the right.
  3. Sony Vaio PCG-3C2L Hard Drive Replacement: step 3, image 1 of 1
    • After unlocking the battery, hold the "release" button and push to the left.
  4. Sony Vaio PCG-3C2L Hard Drive Replacement: step 4, image 1 of 3 Sony Vaio PCG-3C2L Hard Drive Replacement: step 4, image 2 of 3 Sony Vaio PCG-3C2L Hard Drive Replacement: step 4, image 3 of 3
    • Keep the "release" button pressed.
    • Use the iFixit opening tool (or your hands) to lift the battery up.
  5. Sony Vaio PCG-3C2L Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
    • Place the laptop so that the bottom is facing up.
  6. Sony Vaio PCG-3C2L Hard Drive Replacement: step 6, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the two 3.5mm screws on the hard drive cover.
  7. Sony Vaio PCG-3C2L Hard Drive Replacement: step 7, image 1 of 2 Sony Vaio PCG-3C2L Hard Drive Replacement: step 7, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the three 8mm screws on the hard drive casing.
    • Remove the black hard drive casing by pulling it off.
  8. Sony Vaio PCG-3C2L Hard Drive Replacement: step 8, image 1 of 3 Sony Vaio PCG-3C2L Hard Drive Replacement: step 8, image 2 of 3 Sony Vaio PCG-3C2L Hard Drive Replacement: step 8, image 3 of 3
    • Remove the hard drive by carefully sliding it out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 712
