Sony Vaio PCG-3C2L Fan Replacement
  1. Sony Vaio PCG-3C2L Fan Replacement, Battery: step 1, image 1 of 1
    • Turn your computer over so the bottom is facing up.
    • The battery should be in the top on the back of the computer.
  2. Sony Vaio PCG-3C2L Fan Replacement: step 2, image 1 of 2 Sony Vaio PCG-3C2L Fan Replacement: step 2, image 2 of 2
    • Initially, the "lock" button should be pushed all the way to the left. To unlock the battery, move the lock button from the left to the right.
  3. Sony Vaio PCG-3C2L Fan Replacement: step 3, image 1 of 1
    • After unlocking the battery, hold the "release" button and push to the left.
  4. Sony Vaio PCG-3C2L Fan Replacement: step 4, image 1 of 3 Sony Vaio PCG-3C2L Fan Replacement: step 4, image 2 of 3 Sony Vaio PCG-3C2L Fan Replacement: step 4, image 3 of 3
    • Keep the "release" button pressed.
    • Use the iFixit opening tool (or your hands) to lift the battery up.
  5. Sony Vaio PCG-3C2L Fan Replacement, Hard Drive: step 5, image 1 of 1
    • Place the laptop so that the bottom is facing up.
  6. Sony Vaio PCG-3C2L Fan Replacement: step 6, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the two 3.5mm screws on the hard drive cover.
  7. Sony Vaio PCG-3C2L Fan Replacement: step 7, image 1 of 2 Sony Vaio PCG-3C2L Fan Replacement: step 7, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the three 8mm screws on the hard drive casing.
    • Remove the black hard drive casing by pulling it off.
  8. Sony Vaio PCG-3C2L Fan Replacement: step 8, image 1 of 3 Sony Vaio PCG-3C2L Fan Replacement: step 8, image 2 of 3 Sony Vaio PCG-3C2L Fan Replacement: step 8, image 3 of 3
    • Remove the hard drive by carefully sliding it out.
  9. Sony Vaio PCG-3C2L Fan Replacement, Fan: step 9, image 1 of 1
    • Remove the six 8 mm edge screws from the back panel using a Phillips #0 screwdriver.
    • Remove the two 8 mm corner screws from the back panel using a Phillips #0 screwdriver.
    • Remove the four 8 mm middle screws from the back panel using a Phillips #0 screwdriver.
    • Remove the three 2 mm screws from the back panel using a Phillips #0 screwdriver.
  10. Sony Vaio PCG-3C2L Fan Replacement: step 10, image 1 of 1
    • Remove the 6 mm screw from the battery holder using a Phillips #0 screwdriver.
    • Remove the two 4 mm screws from the battery holder using a Phillips #0 screwdriver.
  11. Sony Vaio PCG-3C2L Fan Replacement: step 11, image 1 of 3 Sony Vaio PCG-3C2L Fan Replacement: step 11, image 2 of 3 Sony Vaio PCG-3C2L Fan Replacement: step 11, image 3 of 3
    • Remove the CD cartridge from the back panel by sliding it out.
  12. Sony Vaio PCG-3C2L Fan Replacement: step 12, image 1 of 3 Sony Vaio PCG-3C2L Fan Replacement: step 12, image 2 of 3 Sony Vaio PCG-3C2L Fan Replacement: step 12, image 3 of 3
    • Using your hands, pull up the back panel about two inches up from the rest of the laptop.
    • Disconnect the black wire connector.
    • Remove back panel.
    • Pull up the back panel slowly so the black wire connector does not break.
  13. Sony Vaio PCG-3C2L Fan Replacement: step 13, image 1 of 2 Sony Vaio PCG-3C2L Fan Replacement: step 13, image 2 of 2
    • Unscrew the four 4 mm captive screws from the fan casing using a Phillips #0 screwdriver.
    • Disconnect the black/red/yellow wire connector by gently pulling on the wire.
    • Remove the copper colored fan casing that contains the fan by pulling it off of the bottom of the laptop.
  14. Sony Vaio PCG-3C2L Fan Replacement: step 14, image 1 of 1
    • Remove the three 3 mm fan casing screws from the fan casing using a Phillips #0 screwdriver.
  15. Sony Vaio PCG-3C2L Fan Replacement: step 15, image 1 of 2 Sony Vaio PCG-3C2L Fan Replacement: step 15, image 2 of 2
    • Remove the fan from the fan casing by sliding it out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 759
