Sony Vaio PCG-31311L RAM Replacement
  1. Sony Vaio PCG-31311L RAM Replacement, RAM: step 1, image 1 of 2 Sony Vaio PCG-31311L RAM Replacement, RAM: step 1, image 2 of 2
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew.
    • These screws do not detach from the plate.
  2. Sony Vaio PCG-31311L RAM Replacement: step 2, image 1 of 2 Sony Vaio PCG-31311L RAM Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry up on the bottom plate.
    • Lift up and away from the device.
  3. Sony Vaio PCG-31311L RAM Replacement: step 3, image 1 of 2 Sony Vaio PCG-31311L RAM Replacement: step 3, image 2 of 2
    • Locate the 2 clips on either side of the RAM chip.
    • Push both of them out and away from the RAM chip. The RAM chip should pop up.
    • Slowly remove the chip from the device
    • Make note of which side the slot is on in order to correctly reinstall the RAM chip.
  4. Sony Vaio PCG-31311L RAM Replacement: step 4, image 1 of 2 Sony Vaio PCG-31311L RAM Replacement: step 4, image 2 of 2
    • Repeat Step 3 on the other RAM chip
Tyler
45 Reputation
5 Guides authored
USF Tampa, Team 1-1, Lacy Fall 2016 Member of USF Tampa, Team 1-1, Lacy Fall 2016
USFT-LACY-F16S1G1
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 950
