Sony Vaio PCG-31311L Motherboard Replacement
  1. Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: step 1, image 1 of 2 Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: step 1, image 2 of 2
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew
    • These screws do not detach from the bottom plate.
  2. Sony Vaio PCG-31311L Motherboard Replacement: step 2, image 1 of 2 Sony Vaio PCG-31311L Motherboard Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry up on the plate and remove from device.
  3. Sony Vaio PCG-31311L Motherboard Replacement: step 3, image 1 of 1
    • Locate screw labeled "KB" and remove.
  4. Sony Vaio PCG-31311L Motherboard Replacement: step 4, image 1 of 3 Sony Vaio PCG-31311L Motherboard Replacement: step 4, image 2 of 3 Sony Vaio PCG-31311L Motherboard Replacement: step 4, image 3 of 3
    • Use a plastic opening tool tool to pry around the edge of the keyboard.
  5. Sony Vaio PCG-31311L Motherboard Replacement: step 5, image 1 of 3 Sony Vaio PCG-31311L Motherboard Replacement: step 5, image 2 of 3 Sony Vaio PCG-31311L Motherboard Replacement: step 5, image 3 of 3
    • Once detached, tilt the keyboard forward, exposing a blue ribbon cable.
    • Place finger on black tab and pull back. Then, give a gentle tug on the ribbon cable and it will detach.
    • Once the ribbon cable has been detached, lift the keyboard away from the device.
  6. Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: step 6, image 1 of 2 Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • Use the plastic opening tool to pull back the ribbon cables attached to the motherboard
    • Use the plastic opening tool to pop up the black tabs and pull the remaining ribbon cables.
  7. Sony Vaio PCG-31311L Motherboard Replacement: step 7, image 1 of 2 Sony Vaio PCG-31311L Motherboard Replacement: step 7, image 2 of 2
    • Locate the LCD ribbon cable
    • Pull up and away from device to detach the LCD ribbon cable.
  8. Sony Vaio PCG-31311L Motherboard Replacement: step 8, image 1 of 3 Sony Vaio PCG-31311L Motherboard Replacement: step 8, image 2 of 3 Sony Vaio PCG-31311L Motherboard Replacement: step 8, image 3 of 3
    • Close and flip over laptop.
    • Locate the WiFi network card.
    • Use the plastic opening tool to pry up the two connectors.
  9. Sony Vaio PCG-31311L Motherboard Replacement: step 9, image 1 of 2 Sony Vaio PCG-31311L Motherboard Replacement: step 9, image 2 of 2
    • Locate the 6 screws on the bottom and remove.
    • Remove the final screw in the center to release the motherboard from the case.
Tyler
45 Reputation
5 Guides authored
USF Tampa, Team 1-1, Lacy Fall 2016 Member of USF Tampa, Team 1-1, Lacy Fall 2016
USFT-LACY-F16S1G1
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 1,564
