Sony Vaio Fit SVF15N26CXB Speaker Replacement
  1. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Battery: step 1, image 1 of 2 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Battery: step 1, image 2 of 2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Speaker Replacement: step 2, image 1 of 2 Sony Vaio Fit SVF15N26CXB Speaker Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Speaker Replacement: step 3, image 1 of 3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: step 3, image 2 of 3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: step 3, image 3 of 3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Speaker Replacement: step 4, image 1 of 1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: step 5, image 1 of 3 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: step 5, image 2 of 3 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: step 5, image 3 of 3
    • Remove six 5.75mm Phillips #00 screws from the speakers.
  6. Sony Vaio Fit SVF15N26CXB Speaker Replacement: step 6, image 1 of 3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: step 6, image 2 of 3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: step 6, image 3 of 3
    • Use a spudger to flip up the black latch on the four ZIF connectors.
    • Remove the four ribbon cables from the ZIF connectors.
    • Disconnect the speaker from the board.
  7. Sony Vaio Fit SVF15N26CXB Speaker Replacement: step 7, image 1 of 2 Sony Vaio Fit SVF15N26CXB Speaker Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, carefully unwind the speakers' wires from the plastic brackets holding them.
    • Where the wire is stuck under tape, gently pull the tape up until the wire is free.
    • Do not remove the tape.
  8. Sony Vaio Fit SVF15N26CXB Speaker Replacement: step 8, image 1 of 1
    • Remove the speakers by picking the left and right pieces up and lifting them up and out of the computer.
Althea McDavid
857 Reputation
6 Guides authored
USF Tampa, Team S2-G4, Nance Spring 2018 Member of USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 492
