Sony Vaio Fit SVF15N26CXB Fan Replacement
  1. Sony Vaio Fit SVF15N26CXB Fan Replacement, Battery: step 1, image 1 of 2 Sony Vaio Fit SVF15N26CXB Fan Replacement, Battery: step 1, image 2 of 2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Fan Replacement: step 2, image 1 of 2 Sony Vaio Fit SVF15N26CXB Fan Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Fan Replacement: step 3, image 1 of 3 Sony Vaio Fit SVF15N26CXB Fan Replacement: step 3, image 2 of 3 Sony Vaio Fit SVF15N26CXB Fan Replacement: step 3, image 3 of 3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Fan Replacement: step 4, image 1 of 1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Fan Replacement, Fan: step 5, image 1 of 3 Sony Vaio Fit SVF15N26CXB Fan Replacement, Fan: step 5, image 2 of 3 Sony Vaio Fit SVF15N26CXB Fan Replacement, Fan: step 5, image 3 of 3
    • Remove the four 4.58mm Phillips #00 screws from the cooling system.
    • Unscrew the five Phillips #00 screws from the heatsink.
    • These screws will remain attached to the heatsink.
  6. Sony Vaio Fit SVF15N26CXB Fan Replacement: step 6, image 1 of 2 Sony Vaio Fit SVF15N26CXB Fan Replacement: step 6, image 2 of 2
    • Disconnect the fan from the motherboard.
    • This connector should be pulled upwards, not outwards.
    • Remove the fan unit.
2 other people completed this guide.
Althea McDavid
857 Reputation
6 Guides authored
USF Tampa, Team S2-G4, Nance Spring 2018 Member of USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 752
