Sony Vaio Fit SVF14A190X Battery Replacement
  1. Sony Vaio Fit SVF14A190X  Battery Replacement, Battery Replacement: step 1, image 1 of 1
    • Make sure the battery is drained or the computer is turned off.
    • Use the Phillips head screw driver to remove the eleven 6 mm screws.
    • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
  2. Sony Vaio Fit SVF14A190X  Battery Replacement: step 2, image 1 of 3 Sony Vaio Fit SVF14A190X  Battery Replacement: step 2, image 2 of 3 Sony Vaio Fit SVF14A190X  Battery Replacement: step 2, image 3 of 3
    • Insert the plastic opening tool into the slit of the CD drive.
    • Then pull it outwards.
    • Grab the CD drive with your hand.
    • Take the CD drive all the way out.
  3. Sony Vaio Fit SVF14A190X  Battery Replacement: step 3, image 1 of 3 Sony Vaio Fit SVF14A190X  Battery Replacement: step 3, image 2 of 3 Sony Vaio Fit SVF14A190X  Battery Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
    • Move the plastic opening tool around all sides of the device.
    • Peel off the back cover.
  4. Sony Vaio Fit SVF14A190X  Battery Replacement: step 4, image 1 of 2 Sony Vaio Fit SVF14A190X  Battery Replacement: step 4, image 2 of 2
    • Use the Phillips head screw driver to remove the four 7 mm screws.
    • Lift the battery out with your hand.
Randal Crosby
187 Reputation
1 Guide authored
USF Tampa, Team S11-G3, Cheng Spring 2018 Member of USF Tampa, Team S11-G3, Cheng Spring 2018
USFT-CHENG-S18S11G3
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,870
