Sony Vaio Fit 13A SVF13NA1EL Battery Replacement
  1. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement, Battery: step 1, image 1 of 1
    • Begin by turning the laptop top-down on a flat surface.
    • Use a JIS #1 screwdriver to remove the 4 screws circled in red
    • Use a JIS #0 screwdriver to remove the 8 screws circled in orange
    • Many of these screws are located underneath the rubber pads on the device.
    • Keep track of the locations of the screws removed for ease of reassembly.
  2. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: step 2, image 1 of 1
    • Use a spudger to carefully remove the back cover of the laptop.
    • Be careful when lifting around the ports and headphone jack to avoid causing damage to these components.
  3. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: step 3, image 1 of 2 Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: step 3, image 2 of 2
    • Lift up back cover to access internal components of the laptop.
  4. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: step 4, image 1 of 1
    • Remove the screws in the circled areas using the J0 Screwdriver to release the battery.
  5. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: step 5, image 1 of 2 Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: step 5, image 2 of 2
    • Lift the battery from the laptop to remove.
    • Replace if necessary.
2 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 85
All Time: 3,896
