Sony VAIO VPCEE26FX RAM Replacement
  1. Sony VAIO VPCEE26FX RAM Replacement, Battery: step 1, image 1 of 2 Sony VAIO VPCEE26FX RAM Replacement, Battery: step 1, image 2 of 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX RAM Replacement: step 2, image 1 of 2 Sony VAIO VPCEE26FX RAM Replacement: step 2, image 2 of 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX RAM Replacement, RAM: step 3, image 1 of 1
    • Using a JIS #0 screwdriver, loosen the captive screw attached to the RAM cover.
    • This screw will not come out all the way, but will remain attached to the cover instead.
  4. Sony VAIO VPCEE26FX RAM Replacement: step 4, image 1 of 1
    • Remove the cover which will reveal the two RAM sticks.
  5. Sony VAIO VPCEE26FX RAM Replacement: step 5, image 1 of 3 Sony VAIO VPCEE26FX RAM Replacement: step 5, image 2 of 3 Sony VAIO VPCEE26FX RAM Replacement: step 5, image 3 of 3
    • Push the two tabs holding the RAM sticks in place, away from each other.
    • The first RAM stick will pop up out of place. Remove it away from its position.
  6. Sony VAIO VPCEE26FX RAM Replacement: step 6, image 1 of 3 Sony VAIO VPCEE26FX RAM Replacement: step 6, image 2 of 3 Sony VAIO VPCEE26FX RAM Replacement: step 6, image 3 of 3
    • Push the two tabs holding the second RAM stick in, away from each other.
    • The second RAM stick will pop up out of place. Remove it away from its position.
Christopher Hover
679 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 1,391
