Sony VAIO VPCEE26FX Optical Drive Replacement
  1. Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: step 1, image 1 of 2 Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: step 1, image 2 of 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Optical Drive Replacement: step 2, image 1 of 2 Sony VAIO VPCEE26FX Optical Drive Replacement: step 2, image 2 of 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Optical Drive Replacement, Optical Drive: step 3, image 1 of 1
    • Use a JIS #0 screwdriver to remove the 4mm screw from its place.
  4. Sony VAIO VPCEE26FX Optical Drive Replacement: step 4, image 1 of 2 Sony VAIO VPCEE26FX Optical Drive Replacement: step 4, image 2 of 2
    • Remove the optical drive gently away from its holder on the laptop.
Christopher Hover
679 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 448
