Sony VAIO VPCEE26FX Keyboard Replacement
  1. Sony VAIO VPCEE26FX Keyboard Replacement, Battery: step 1, image 1 of 2 Sony VAIO VPCEE26FX Keyboard Replacement, Battery: step 1, image 2 of 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Keyboard Replacement: step 2, image 1 of 2 Sony VAIO VPCEE26FX Keyboard Replacement: step 2, image 2 of 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: step 3, image 1 of 2 Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: step 3, image 2 of 2
    • Flip the laptop back over so it is face up.
    • Open up the laptop.
  4. Sony VAIO VPCEE26FX Keyboard Replacement: step 4, image 1 of 1
    • Using a plastic opening tool, pry along the seam between the keyboard and case to help in separating the two.
    • Continue to lift up gently using the plastic opening tool until the keyboard begins to separate from the case.
  5. Sony VAIO VPCEE26FX Keyboard Replacement: step 5, image 1 of 2 Sony VAIO VPCEE26FX Keyboard Replacement: step 5, image 2 of 2
    • Continue lifting up and moving down starting on the left side of the keyboard moving towards the right side of the computer.
  6. Sony VAIO VPCEE26FX Keyboard Replacement: step 6, image 1 of 2 Sony VAIO VPCEE26FX Keyboard Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully tilt the top of the keyboard towards you ensuring the ribbon cable is not under too much tension.
    • Use a pair of tweezers to help remove the plastic adhesive film covering the adapter/port for the ribbon cable.
  7. Sony VAIO VPCEE26FX Keyboard Replacement: step 7, image 1 of 1
  8. Sony VAIO VPCEE26FX Keyboard Replacement: step 8, image 1 of 1
    • Lift the keyboard up and away from the computer.
Christopher Hover
679 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 20
All Time: 1,172
