Sony VAIO VPC-EB33FM RAM Replacement
  1. Sony VAIO VPC-EB33FM RAM Replacement, Battery: step 1, image 1 of 2 Sony VAIO VPC-EB33FM RAM Replacement, Battery: step 1, image 2 of 2
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Sony VAIO VPC-EB33FM RAM Replacement: step 2, image 1 of 1
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Sony VAIO VPC-EB33FM RAM Replacement: step 3, image 1 of 2 Sony VAIO VPC-EB33FM RAM Replacement: step 3, image 2 of 2
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Sony VAIO VPC-EB33FM RAM Replacement, RAM: step 4, image 1 of 3 Sony VAIO VPC-EB33FM RAM Replacement, RAM: step 4, image 2 of 3 Sony VAIO VPC-EB33FM RAM Replacement, RAM: step 4, image 3 of 3
    • Remove the one screw with a Phillips #00 screwdriver.
    • The screw cannot be removed from the RAM casing cover.
  5. Sony VAIO VPC-EB33FM RAM Replacement: step 5, image 1 of 2 Sony VAIO VPC-EB33FM RAM Replacement: step 5, image 2 of 2
    • Pull the two retaining arms away from the center of the RAM chip.
    • The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
  6. Sony VAIO VPC-EB33FM RAM Replacement: step 6, image 1 of 3 Sony VAIO VPC-EB33FM RAM Replacement: step 6, image 2 of 3 Sony VAIO VPC-EB33FM RAM Replacement: step 6, image 3 of 3
    • Pull the RAM stick out of its socket.
    • To remove the second stick of RAM, repeat steps six and seven.
    • When installing RAM, make sure sticks are firmly in place or the computer will not register them.
Bret Omsberg
16 Reputation
1 Guide authored
Cal Poly, Team 18-39, Regan Winter 2013 Member of Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Members
15 Guides authored
One Comment
when i press the power button in VAio still black screen with little tick sound,
and one day i just turn it on and leave it for 17 hours and sadnlley it worked but when i tried to restart it it still not working with tick tick tick tick sound !!! any advise !!!?
dorii135 - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 20
All Time: 4,308
