Sony VAIO VPC-EB33FM Fan Replacement
  1. Sony VAIO VPC-EB33FM Fan Replacement, Battery: step 1, image 1 of 2 Sony VAIO VPC-EB33FM Fan Replacement, Battery: step 1, image 2 of 2
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Sony VAIO VPC-EB33FM Fan Replacement: step 2, image 1 of 1
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Sony VAIO VPC-EB33FM Fan Replacement: step 3, image 1 of 2 Sony VAIO VPC-EB33FM Fan Replacement: step 3, image 2 of 2
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Sony VAIO VPC-EB33FM Fan Replacement, Hard Drive: step 4, image 1 of 3 Sony VAIO VPC-EB33FM Fan Replacement, Hard Drive: step 4, image 2 of 3 Sony VAIO VPC-EB33FM Fan Replacement, Hard Drive: step 4, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
  5. Sony VAIO VPC-EB33FM Fan Replacement: step 5, image 1 of 3 Sony VAIO VPC-EB33FM Fan Replacement: step 5, image 2 of 3 Sony VAIO VPC-EB33FM Fan Replacement: step 5, image 3 of 3
    • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
    • You may need to use your other hand to safely remove the panel.
    • You can also use a spudger for this step.
  6. Sony VAIO VPC-EB33FM Fan Replacement: step 6, image 1 of 1
    • Remove the two remaining 7.8 mm screws using the Phillips #00 screwdriver.
  7. Sony VAIO VPC-EB33FM Fan Replacement: step 7, image 1 of 1
    • Grab the tab between your thumb and index finger.
    • Hold the hard drive securely in a horizontal position using your other hand.
    • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
    • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
  8. Sony VAIO VPC-EB33FM Fan Replacement: step 8, image 1 of 2 Sony VAIO VPC-EB33FM Fan Replacement: step 8, image 2 of 2
    • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
    • Pull the hard drive out.
  9. Sony VAIO VPC-EB33FM Fan Replacement: step 9, image 1 of 2 Sony VAIO VPC-EB33FM Fan Replacement: step 9, image 2 of 2
    • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
  10. Sony VAIO VPC-EB33FM Fan Replacement, RAM: step 10, image 1 of 3 Sony VAIO VPC-EB33FM Fan Replacement, RAM: step 10, image 2 of 3 Sony VAIO VPC-EB33FM Fan Replacement, RAM: step 10, image 3 of 3
    • Remove the one screw with a Phillips #00 screwdriver.
    • The screw cannot be removed from the RAM casing cover.
  11. Sony VAIO VPC-EB33FM Fan Replacement: step 11, image 1 of 2 Sony VAIO VPC-EB33FM Fan Replacement: step 11, image 2 of 2
    • Pull the two retaining arms away from the center of the RAM chip.
    • The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
  12. Sony VAIO VPC-EB33FM Fan Replacement: step 12, image 1 of 3 Sony VAIO VPC-EB33FM Fan Replacement: step 12, image 2 of 3 Sony VAIO VPC-EB33FM Fan Replacement: step 12, image 3 of 3
    • Pull the RAM stick out of its socket.
    • To remove the second stick of RAM, repeat steps six and seven.
    • When installing RAM, make sure sticks are firmly in place or the computer will not register them.
  13. Sony VAIO VPC-EB33FM Fan Replacement, Fan: step 13, image 1 of 1
    • Remove the following 16 screws securing the back cover using a Phillips #00 screwdriver:
    • Two 3.8-mm screws
    • Two 8.9-mm screws
    • Twelve 7.75-mm screws
  14. Sony VAIO VPC-EB33FM Fan Replacement: step 14, image 1 of 1
    • Check to make sure all the screws have been removed.
    • Using both hands, separate the back cover by lifting from the back and working around the perimeter to release tabs.
  15. Sony VAIO VPC-EB33FM Fan Replacement: step 15, image 1 of 2 Sony VAIO VPC-EB33FM Fan Replacement: step 15, image 2 of 2
    • Locate the fan and the processor attachment.
  16. Sony VAIO VPC-EB33FM Fan Replacement: step 16, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the top four 3.88-mm fan screws.
  17. Sony VAIO VPC-EB33FM Fan Replacement: step 17, image 1 of 1
    • Remove the two 5.7-mm screws located at the base of the fan, using a Phillips #00 screwdriver.
  18. Sony VAIO VPC-EB33FM Fan Replacement: step 18, image 1 of 1
    • Pull back the tape located on the far side of the fan.
  19. Sony VAIO VPC-EB33FM Fan Replacement: step 19, image 1 of 1
    • Remove the wired connection between the fan and the copper wire using metal tweezers.
    • Do not to pull on the wires directly or it will damage the connection between the fan and the laptop.
  20. Sony VAIO VPC-EB33FM Fan Replacement: step 20, image 1 of 1
    • Remove the four 5.65-mm screws on the processor corners using a Phillips #00 screwdriver.
  21. Sony VAIO VPC-EB33FM Fan Replacement: step 21, image 1 of 2 Sony VAIO VPC-EB33FM Fan Replacement: step 21, image 2 of 2
    • You are now ready to remove fan and processor connection
    • Position thumbs and index fingers close to processor and lift up on the copper wire, while applying slight downward pressure on the motherboard with remaining fingers.
    • If there is thermal paste between the processor and the fan attachment, increased force will be required to detach the fan.
16 other people completed this guide.
Kevin
513 Reputation
3 Guides authored
Cal Poly, Team 18-39, Regan Winter 2013 Member of Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Members
15 Guides authored
3 Comments
I don't know who you are, but you are a god to me!! Laptop is fixed and humming along like it is supposed to!!
Great and easy directions, thank you from the bottom of my heart....and the bottom of my husbands wallet!
creaper126 - Reply
Hi, I would like to upgrade my core i3 370M processor. How can I know the compatible core i5 or i7 to replace?
Material
Tudo praObra - Reply
Thanks!! This is very helpful.
Charlie Tai - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 21
All Time: 20,235
