Sony SRS-XE200 Motherboard Replacement
  1. Sony SRS-XE200 Motherboard Replacement, Speaker Assembly: step 1, image 1 of 2 Sony SRS-XE200 Motherboard Replacement, Speaker Assembly: step 1, image 2 of 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Motherboard Replacement: step 2, image 1 of 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Motherboard Replacement: step 3, image 1 of 2 Sony SRS-XE200 Motherboard Replacement: step 3, image 2 of 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Motherboard Replacement: step 4, image 1 of 2 Sony SRS-XE200 Motherboard Replacement: step 4, image 2 of 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Motherboard Replacement, Motherboard: step 5, image 1 of 3 Sony SRS-XE200 Motherboard Replacement, Motherboard: step 5, image 2 of 3 Sony SRS-XE200 Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Motherboard Replacement: step 6, image 1 of 1
    • Remove the cord connecting the charging port to the motherboard.
  7. Sony SRS-XE200 Motherboard Replacement: step 7, image 1 of 3 Sony SRS-XE200 Motherboard Replacement: step 7, image 2 of 3 Sony SRS-XE200 Motherboard Replacement: step 7, image 3 of 3
    • Remove the two 0.8 mm screws attaching the motherboard to the case compartment with a Phillips #1 screwdriver.
    • Detach the motherboard from the case compartment.
One Comment
Hy please I m from morrocco i need a matherbeard a have a speaker but not work i d'not no way i need help plz
Abdou Abdou - Reply
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 28
All Time: 361
