Sony SLT Alpha-65V Flash Capacitor Replacement
  1. Sony SLT Alpha-65V Flash Capacitor Replacement, Back Panel: step 1, image 1 of 1
    • Unscrew the four 4.0 mm Phillips #00 screws with a on the base of the camera below the the scheme that separates the front and back panels.
    • Unscrew the 5.0 mm Phillips #00 screw on the bottom right of the camera.
  2. Sony SLT Alpha-65V Flash Capacitor Replacement: step 2, image 1 of 1
    • Unscrew the 4.0 mm Phillips #00 screw on bottom of the left side of the camera.
    • Unscrew the 5.0 mm Phillips #00 screw near the top of the left side of the camera.
  3. Sony SLT Alpha-65V Flash Capacitor Replacement: step 3, image 1 of 1
    • Be careful when pulling the back panel away as it will still be connected to the body of the camera by two strips of film.
    • When unscrewing the 5.0 mm screw on the dial, make sure to hold onto the dial that becomes detached after taking out the screw.
    • Unscrew the two 4.0 mm Phillips #00 screw at the top of the camera by the eyepiece.
    • Unscrew the 5.0 mm Phillips #00 screw of the dial below the other two screws.
    • Once all the screws are removed, carefully use your hands to detach the back panel from the camera. Working around the edges can help as well.
  4. Sony SLT Alpha-65V Flash Capacitor Replacement: step 4, image 1 of 3 Sony SLT Alpha-65V Flash Capacitor Replacement: step 4, image 2 of 3 Sony SLT Alpha-65V Flash Capacitor Replacement: step 4, image 3 of 3
    • Remove the two 4.0 mm Phillips #00 screws on the right of the camera that are located on the upper right side and under the "Remote" port flap.
    • Detach the right side panel with the remote and HDMI ports of the camera by gently pulling on the panel.
  5. Sony SLT Alpha-65V Flash Capacitor Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • When the back panel is removed, be careful when moving the camera. There are parts inside the camera which now may come loose.
    • Use tweezers to remove the blue and orange ribbon connectors from their connection points pictured here.
  6. Sony SLT Alpha-65V Flash Capacitor Replacement, Motherboard: step 6, image 1 of 1
    • Remove the four 3.0 mm Phillips #00 screws.
    • Remove the 5.0 mm Phillips #00 screw.
  7. Sony SLT Alpha-65V Flash Capacitor Replacement: step 7, image 1 of 3 Sony SLT Alpha-65V Flash Capacitor Replacement: step 7, image 2 of 3 Sony SLT Alpha-65V Flash Capacitor Replacement: step 7, image 3 of 3
    Buy
    • Don't forget to close these switches and lock the film back into place when reassembling the camera.
    • Use your finger to flip the switch that holds the dual ribbon connector in place.
    • Gently use tweezers to disconnect the dual ribbon connector and the thin blue ribbon connector to the right of it from the circuit board.
  8. Sony SLT Alpha-65V Flash Capacitor Replacement: step 8, image 1 of 3 Sony SLT Alpha-65V Flash Capacitor Replacement: step 8, image 2 of 3 Sony SLT Alpha-65V Flash Capacitor Replacement: step 8, image 3 of 3
    • Use tweezers to disconnect the blue, gold, and brown ribbon connectors near the top of the camera.
  9. Sony SLT Alpha-65V Flash Capacitor Replacement: step 9, image 1 of 2 Sony SLT Alpha-65V Flash Capacitor Replacement: step 9, image 2 of 2
    • Use a plastic opening tool to pop open the connector holding the next ribbon to the circuit board.
    • Use tweezers to disconnect the ribbon.
  10. Sony SLT Alpha-65V Flash Capacitor Replacement: step 10, image 1 of 1
    • Use tweezers to unplug the blue adapter located at the top right of the circuit board.
  11. Sony SLT Alpha-65V Flash Capacitor Replacement: step 11, image 1 of 1
    • Use either plastic opening tools or tweezers to unplug the white adapter located on the right side of the circuit board.
  12. Sony SLT Alpha-65V Flash Capacitor Replacement: step 12, image 1 of 1
    • The circuit board will still be connected to the body of the camera by two pairs of cords.
    • Gently lift the circuit board away from the camera and turn it over.
    • Use tweezers to disconnect the final two plugs and completely remove the circuit board from the camera.
  13. Sony SLT Alpha-65V Flash Capacitor Replacement, Flash Capacitor: step 13, image 1 of 1
    • Remove the 5.0 mm Phillips #00 screw on the right side of the flash capacitor.
  14. Sony SLT Alpha-65V Flash Capacitor Replacement: step 14, image 1 of 1
    • Remove the 5.0 mm Phillips #00 screw on the left side of the camera next to the flash capacitor.
  15. Sony SLT Alpha-65V Flash Capacitor Replacement: step 15, image 1 of 3 Sony SLT Alpha-65V Flash Capacitor Replacement: step 15, image 2 of 3 Sony SLT Alpha-65V Flash Capacitor Replacement: step 15, image 3 of 3
    • The small hole in the ribbon shown with the red square may get caught in the pin it goes around. Make sure to gently lift the ribbon from this point first before anywhere else.
    • Gently lift the circuit ribbon off the camera and maneuver the ribbon around the plastic bearings until it comes completely off.
    • The flash capacitor will be soldered into the part that detaches from the camera. This entire part will need to be replaced.
5 other people completed this guide.
Dima Kyle
513 Reputation
2 Guides authored
Cal Poly, Team 14-11, Amido Spring 2015 Member of Cal Poly, Team 14-11, Amido Spring 2015
CPSU-AMIDO-S15S14G11
4 Members
13 Guides authored
One Comment
This is a welcome and well-illustrated guide. However, I don't necessarily agree that it qualifies as "easy". Also, and it seems to me this is very important, capacitors can maintain a significant electric charge for extended periods even when the battery has been removed and the camera is "off". The capacitor should be discharged before attempting to effect a repair. Finally, if one is experienced with soldering, the capacitor may be successfully replaced at very little cast (for the capacitor), thereby obviating the need to purchase the entire board.
Keith Pyne Howarth - Reply
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 25
All Time: 1,536
