Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement
  1. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Disassembling: step 1, image 1 of 3 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Disassembling: step 1, image 2 of 3 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Disassembling: step 1, image 3 of 3
    • Detach the back cover from the e-reader
    • Remove the black sticker, uncovering three additional screws. The sticker comes loose quite easy.
    • Unscrew all 10 screws (length 3.2mm).
    • Now take a spudger, and start opening the case at the top. There are four retaining clips at each side.
  2. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 2, image 1 of 1
    • Under the cover you'll find many interesting things.
  3. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 3, image 1 of 1
    • Unscrew these 5 screws (length 4.3mm) . They hold the front bezel (white or black part of the main body).
    • There are other screws that hold the motherboard (10×, 1.8mm) to the grey back plate. You do not need to remove them, unless you want to remove the electronics board (for example to prevent damage when cleaning the back plate in a later step).
  4. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 4, image 1 of 3 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 4, image 2 of 3 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 4, image 3 of 3
    • Carefully unplug buses. For the screen bus. Simple pull it from connector. For the hard keys bus . First, open the connector by hook it from below. Then it'll be easy to unplug the bus.
  5. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 5, image 1 of 2 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 5, image 2 of 2
    • Carefully unglue the Wifi antenna.
  6. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 6, image 1 of 2 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 6, image 2 of 2
    • Now we need to remove a white cover. It helds by clips around the body. Please, pay attention to hooks in red ellipses on the photo. On the second photo you may see detached white cover.
  7. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 7, image 1 of 3 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 7, image 2 of 3 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 7, image 3 of 3
    • Unscrew screws marked by red cicles.
    • Carefully unplug a bus
    • Be careful, do not lose this tiny thing!
    • Remove black frame. It's attached to the screen by double sided tape
  8. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 8, image 1 of 3 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 8, image 2 of 3 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: step 8, image 3 of 3
    • Use any suitable knife to detach broken screen from metal plate. Please, be very careful. Do not hurt yourself!
    • After you did this. You need to clean metal plate from the remnants of glue and double sided tape.
  9. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Screen assembling: step 9, image 1 of 3 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Screen assembling: step 9, image 2 of 3 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Screen assembling: step 9, image 3 of 3
    • Take a new screen. Apply double sided tape on back side.
    • Remove protective film from the screen
    • Put the screen into the black frame. Upper side of the screen should touch upper side of the frame.
  10. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Gluing  the screen to the surface: step 10, image 1 of 2 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Gluing  the screen to the surface: step 10, image 2 of 2
    • Carefully join the screen in a black frame with the metal plate.
    • Continue assembling in a reverse order
8 other people completed this guide.
mrdkonst
223 Reputation
1 Guide authored
18 Comments
This an incredibly useful guide. I have the new screen, but I have asked and have not gotten an answer about what double-sided tape is used to attach the new screen to the body. Could someone supply this information pleasae.
kgarnjost - Reply
You may use any double-sided tape you'll find in a shop. I used a 0.5 mm tape or thinner. I found it in a Stationary shop.
mrdkonst -
Is the ED060XC5(LF)C1 screen, the same quality and matte as the original one? I don't trust asian sellers so much, but the only one that I found on internet is this one.
http://es.aliexpress.com/item/100-new-or...
Ale - Reply
In my case it has the same quality. I bought it on Aliexpress also.
mrdkonst -
After installing replacement screen the touch functionallity does not work, screen itself seems to work but you cannot make any touch selections, does anyone has an idea?
hansbergman767 - Reply
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 59
All Time: 8,017
