Sony Laptop VGN-FE31Z LCD Repair
  1. Sony Laptop VGN-FE31Z LCD Repair, Sony Laptop VGN-FE31Z LCD Repair: step 1, image 1 of 1
    • This problem has already happened in many electronic devices in my home, almost every year. The solution is simple: to dismantle the machine completely and remove all traces of soil, ants and dirt.
    • Researching a little on Google, I found the repair manual of the Sony Vaio VGN FE31Z at this address: http://www.givemefile.net/smanuals/noteb...
    • Procedures carefully dismantling the equipment until the LCD. While performing this procedure, I noticed that the ants began to move from side to side, Laptop Keyboard leaving and entering the LCD.
    • The ants have focused on two points: the LVDS and backlight ballast.
    • I removed all electrical parts and proceeded to clean all plastic casing of the laptop, with water and detergent. While the coating was dry, I used isopropyl alcohol to clean the traces of soil. I applied a clean contact solution and the other in LVDS connectors.
    • I mounted the LCD, putting a little poison for ants to prevent future infestations.
Attached Documents
Djair Guilherme
114 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 2,435
