Sony Ericsson W200i Speaker Replacement
  1. Sony Ericsson W200i Speaker Replacement, Disassembling Sony Ericsson W200i Battery: step 1, image 1 of 2 Sony Ericsson W200i Speaker Replacement, Disassembling Sony Ericsson W200i Battery: step 1, image 2 of 2
    • Slide the battery cover up and off the phone.
  2. Sony Ericsson W200i Speaker Replacement: step 2, image 1 of 2 Sony Ericsson W200i Speaker Replacement: step 2, image 2 of 2
    • Pop the battery out of its slot by lifting it up.
  3. Sony Ericsson W200i Speaker Replacement, Front Case: step 3, image 1 of 3 Sony Ericsson W200i Speaker Replacement, Front Case: step 3, image 2 of 3 Sony Ericsson W200i Speaker Replacement, Front Case: step 3, image 3 of 3
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Sony Ericsson W200i Speaker Replacement, Core: step 4, image 1 of 2 Sony Ericsson W200i Speaker Replacement, Core: step 4, image 2 of 2
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
  5. Sony Ericsson W200i Speaker Replacement: step 5, image 1 of 3 Sony Ericsson W200i Speaker Replacement: step 5, image 2 of 3 Sony Ericsson W200i Speaker Replacement: step 5, image 3 of 3
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
  6. Sony Ericsson W200i Speaker Replacement, Back Case: step 6, image 1 of 3 Sony Ericsson W200i Speaker Replacement, Back Case: step 6, image 2 of 3 Sony Ericsson W200i Speaker Replacement, Back Case: step 6, image 3 of 3
    • Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
    • Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
    • Remove the white plastic cover.
  7. Sony Ericsson W200i Speaker Replacement, Speaker: step 7, image 1 of 2 Sony Ericsson W200i Speaker Replacement, Speaker: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the speaker by pulling it up and out of place with the tweezers.
Andy Whitmyre
147 Reputation
1 Guide authored
Cal Poly, Team 14-10, Forte Winter 2011 Member of Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 11
All Time: 4,826
