Sony Ericsson T68i Logic Board Replacement
  1. Sony Ericsson T68i Logic Board Replacement, Keypad: step 1, image 1 of 2 Sony Ericsson T68i Logic Board Replacement, Keypad: step 1, image 2 of 2
    • Remove the battery from the back.
  2. Sony Ericsson T68i Logic Board Replacement: step 2, image 1 of 3 Sony Ericsson T68i Logic Board Replacement: step 2, image 2 of 3 Sony Ericsson T68i Logic Board Replacement: step 2, image 3 of 3
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Sony Ericsson T68i Logic Board Replacement: step 3, image 1 of 3 Sony Ericsson T68i Logic Board Replacement: step 3, image 2 of 3 Sony Ericsson T68i Logic Board Replacement: step 3, image 3 of 3
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Sony Ericsson T68i Logic Board Replacement: step 4, image 1 of 3 Sony Ericsson T68i Logic Board Replacement: step 4, image 2 of 3 Sony Ericsson T68i Logic Board Replacement: step 4, image 3 of 3
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  5. Sony Ericsson T68i Logic Board Replacement, Screen: step 5, image 1 of 3 Sony Ericsson T68i Logic Board Replacement, Screen: step 5, image 2 of 3 Sony Ericsson T68i Logic Board Replacement, Screen: step 5, image 3 of 3
    • Remove the circuit board and screen from the device.
    • Use your T6 to remove the 4 screws.
  6. Sony Ericsson T68i Logic Board Replacement: step 6, image 1 of 3 Sony Ericsson T68i Logic Board Replacement: step 6, image 2 of 3 Sony Ericsson T68i Logic Board Replacement: step 6, image 3 of 3
    • Remove the board and screen.
  7. Sony Ericsson T68i Logic Board Replacement: step 7, image 1 of 3 Sony Ericsson T68i Logic Board Replacement: step 7, image 2 of 3 Sony Ericsson T68i Logic Board Replacement: step 7, image 3 of 3
    • Carefully remove the plastic clips holding the screen on the board.
  8. Sony Ericsson T68i Logic Board Replacement, Logic Board: step 8, image 1 of 3 Sony Ericsson T68i Logic Board Replacement, Logic Board: step 8, image 2 of 3 Sony Ericsson T68i Logic Board Replacement, Logic Board: step 8, image 3 of 3
    • Remove the plate protecting the more delicate processing parts from the logic board.
Tim Dascomb
159 Reputation
7 Guides authored
Cal Poly, Team 26-34, Regan Spring 2010 Member of Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 8
All Time: 2,083
