Sony Cyber-shot DSC-W800 Button Board Replacement
  1. Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: step 1, image 1 of 3 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: step 1, image 2 of 3 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: step 1, image 3 of 3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Button Board Replacement: step 2, image 1 of 2 Sony Cyber-shot DSC-W800 Button Board Replacement: step 2, image 2 of 2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Button Board Replacement: step 3, image 1 of 3 Sony Cyber-shot DSC-W800 Button Board Replacement: step 3, image 2 of 3 Sony Cyber-shot DSC-W800 Button Board Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
3 other people completed this guide.
Thomas Campo
788 Reputation
4 Guides authored
USF Tampa, Team 17-5, Blackwell Winter 2016 Member of USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Members
5 Guides authored
4 Comments
Thanks for this - was spot on and allowed me to easily fix the problem I was experiencing!
jimbradshaw - Reply
follow the step camera button loosen a bit unstuck but camera still stock on language setting and do not budge
Trisha Amable Girlfridayz - Reply
follow the step the button are unstuck but the camera display still stock on language setting
i need a new strip, because old strip was damaged.
moonbhaai@gmail.com
Naveed Shoukat - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 44
All Time: 2,394
