Sony Cyber-shot DSC-W570 LCD Screen Replacement
  1. Sony Cyber-shot DSC-W570 LCD Screen  Replacement, Case Cover: step 1, image 1 of 1
    • Remove the two Phillips head, 2.93 mm long screws at the bottom of the camera.
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 2, image 1 of 1
    • Turn the camera sideways so the left side is fasning upwards, remove the two Phillips head, 2.93 mm screws.
  3. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 3, image 1 of 1
    • Now turn the device so the opposite side is fasning upwards and remove the last two Phillips head, 2.93 mm screws.
  4. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 4, image 2 of 2
    • To remove the front cover, use a plastic opening tool gently pry the top cover.
    • Then gently lift the cover off.
  5. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 5, image 2 of 2
    • To remove the back case cover from the body.
    • First use a plastic opening tool gently pry along the side of the camera.
    • Then slowly and gently lift the cover off.
  6. Sony Cyber-shot DSC-W570 LCD Screen  Replacement, LCD Screen: step 6, image 1 of 1
    • These are the two cables connecting the LCD screen to the motherboard below the screen.
  7. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 7, image 1 of 1
    • Remove the LCD screen from the side opppsite the battery terminals. Watch for the two cords mentioned in the previous step. These will still be connected.The side will flip up as shown in the next step.
  8. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 8, image 1 of 1
    • Pull these two cords straight back to disconnect them from the respective housings. Caution: The housing do not need to be moved or adjusted in anyway. Do not pull the cords at an angle, it can destroy the cords and the housing. Pull Straight Back!
  9. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 9, image 1 of 1
    • This is what the camera should look like after 2 cords and the screen have been removed. The lens cord is being held to the side for a clearer view.
Thomas Plummer
164 Reputation
1 Guide authored
USF Tampa, Team 9-1, Brown Winter 2015 Member of USF Tampa, Team 9-1, Brown Winter 2015
USFT-BROWN-W15S9G1
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 30
All Time: 1,091
