Sony Cyber-shot DSC-HX1 Button Assembly Replacement
  1. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Battery: step 1, image 1 of 1
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: step 2, image 1 of 1
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: step 3, image 1 of 2 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: step 3, image 2 of 2
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
  4. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Button Assembly: step 4, image 1 of 1
    • On the top of the inside the battery compartment, remove the #00 6.0 mm Phillips screw.
  5. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: step 5, image 2 of 2
    • Lift the button housing from its position on top of the camera.
Brianna Greenlaw
1,181 Reputation
5 Guides authored
Cal Poly, Team 17-3, Forte Spring 2015 Member of Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 859
