Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement
  1. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement, Battery: step 1, image 1 of 1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: step 2, image 1 of 1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: step 3, image 1 of 1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement, Front and Back Panel: step 4, image 1 of 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement, Front and Back Panel: step 4, image 2 of 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement, Front and Back Panel: step 4, image 3 of 3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: step 5, image 1 of 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: step 5, image 2 of 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: step 5, image 3 of 3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: step 6, image 1 of 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: step 6, image 2 of 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: step 6, image 3 of 3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
Tong Tang
557 Reputation
4 Guides authored
USF Tampa, Team 17-1, Blackwell Fall 2016 Member of USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 21
All Time: 1,109
