Sony Clie PEG-NR70 Speaker Replacement
  1. Sony Clie PEG-NR70 Speaker Replacement, The Case: step 1, image 1 of 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Speaker Replacement: step 2, image 1 of 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Speaker Replacement: step 3, image 1 of 2 Sony Clie PEG-NR70 Speaker Replacement: step 3, image 2 of 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Speaker Replacement, Speaker Rail: step 4, image 1 of 2 Sony Clie PEG-NR70 Speaker Replacement, Speaker Rail: step 4, image 2 of 2
    • Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
    • Be careful not to tear the speaker wires! They are very thin.
    • Remove the tape holding speaker wire by peeling it away.
  5. Sony Clie PEG-NR70 Speaker Replacement: step 5, image 1 of 1
    • Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
    • Remove the speaker rail vertically from the device.
  6. Sony Clie PEG-NR70 Speaker Replacement, Speaker: step 6, image 1 of 1
    • Hold back the plastic tabs to pop the speaker out of the rail.
Daniel Soski
57 Reputation
6 Guides authored
Cal Poly, Team 14-11, Maness Spring 2013 Member of Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 6
All Time: 308
