Sony CFS-204 Radio Cassette-Corder Batteries Replacement
  1. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: step 1, image 1 of 1
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: step 2, image 1 of 3 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: step 2, image 2 of 3 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: step 2, image 3 of 3
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 1,905
